AF Help & Suggestion Center Need help with Acura Forum? Ask... Have a suggestion to better Acura Forum? Tell us here...
90 Legend LS will not start
Old Jun 14, 2007 | 04:26 PM
1990legendLS's Avatar
<DIV id=post_message_1254221>I recently purchased a 1990 Legend LS (first time Acura owner)I ripped out all the carpet and seats and when I was reinstalling the new carpet I had to disconnect the Alarm box under the drivers seat and now it will not start.I did not receive a remote with the car only a single key.All the dash lights light up and all accessories work but when you turn the key all the way to turn the engine ---nothing ,I hear the what I believe is the starter relay to click on passenger side floor board above foot level to click.The ECU only flashes once just for a second when you turn on the key. I have also pulled the fuse under the hood to reset the ECU.I found some info on alldatapro.com but I cannot find wiring diagrams to either bypass the alarm or better yet to reset the alarm.</DIV>
Old Aug 21, 2007 | 03:42 AM
vincentriley's Avatar
Originally Posted by 1990legendLS
<div id="post_message_1254221">I recently purchased a 1990 Legend LS (first time Acura owner)I ripped out all the carpet and seats and when I was reinstalling the new carpet I had to disconnect the Alarm box under the drivers seat and now it will not start.I did not receive a remote with the car only a single key.All the dash lights light up and all accessories work but when you turn the key all the way to turn the engine ---nothing ,I hear the what I believe is the starter relay to click on passenger side floor board above foot level to click.The ECU only flashes once just for a second when you turn on the key. I have also pulled the fuse under the hood to reset the ECU.I found some info on alldatapro.com but I cannot find wiring diagrams to either bypass the alarm or better yet to reset the alarm.</div>
Might be the harness.. They might have touched it or somethn.. Thats why its not startin at all..
Old Sep 17, 2007 | 12:29 PM
does it crankover???
but no vroom???
Old Apr 25, 2008 | 12:28 AM
bombs's Avatar
We have same problem so I drop mine to shop then
the mechanic told me that the problem is my Acura Vigor Alternator, do I need to
purchase a new one?</span>
Edited by: bombs
Old Apr 27, 2008 | 07:55 AM
can you put the alarm box back in it and see if it runs and starts?
acuraman1994
Jul 10, 2009 07:09 PM
Robb
Jul 22, 2008 10:24 PM
jeu510
Jan 7, 2008 10:42 AM
j9j9j9
Oct 2, 2007 09:25 PM
spokessparks
Jan 21, 2007 06:45 PM
