Computer & Fuel Systems Talk about the control module, fuel systems and delivery, customization and more...
DIY fuel injector removal and install
Old Dec 4, 2005 | 12:41 PM
blackcloud300's Avatar
have any of you tried this? how hard or easy is it to do this kind of job on a 91 integra with 243K on the odometer. this car underwent a major tune up andtiming belt replacement. it runs better than it does when i first got it now but there is still that hesitation when i slow down and then go or when i downshift. my mechanic said it might be the injectors are clogged up and need to be cleaned. any comments or suggestions?
Old Dec 16, 2005 | 01:59 PM
Patrick's Avatar
Administrator
what engine is it?
Old Sep 18, 2006 | 11:58 PM
things to look at or have checked.
slop in the throttle body (butterfly plate)
weak fuel pressures
vacume leaks
temp sender out of range
worn out engine mounts can cause a hesitation, but usually with a big thump sound following.
Old Aug 8, 2007 | 10:50 PM
nosaj81_2004's Avatar
Member
more than likely that car has a b18a1 engine. over the next few gas tanks put some fuel injector cleaner in your tank. That helped out my car whenI first bought it.
maggiesmim
Mar 4, 2015 01:12 AM
cali707
Jun 12, 2008 08:03 PM
Ride.Guide
May 6, 2008 07:36 AM
JBGS-R
Sep 14, 2007 06:07 AM
