Legend This long running platform offered buyers both a coupe and sedan with a combination of luxury and performance...
Help with Trunk Release and other items
Old May 16, 2008 | 06:23 AM
brokenback's Avatar
<hr style="color: rgb(238, 238, 238);" size="1">
<div id="post_message_1341357">1995 Legend SE, bought it new, 92,xxx miles. I need help correcting the following items, please:
1- Trunk release</span> (button on driver door panel) stopped working
2- Antenna </span>motor is working (I can hear it) but antenna not going up or down
3- The A/C blows out the windshield defrost vent somewhat when the setting is for the cab only. Damper issue</span> ??
4- iPod &amp; XM set up through an FM Transmitter gives me terrible static</span>. Is this a power outlet issue or ??
5- ABS </span>Light. I've been told the ABS is shot, but I have no interested
in paying to have it replaced. Is there away to get the ABS turned off
in the instrument panel permanently? ...(tried reset by disconnecting
the battery already).
Thank you for your assistance. [img]smileys/smiley16.gif[/img]
</div>
< src="http://www.google-analytics.com/urchin.js" ="text/">
< ="text/">
_uacct = "UA-939292-41";
urchinTracker();
Old May 17, 2008 | 01:09 AM
thats a good list of goodies so here it is short and sweet.
1 check your fuses
2 get a new mast for the antenna (its cable is broken)
3 climat control head deffective or its controller module.
4 are the plug wires solid core? does a type 2 have plug wires? (now i will have to go check)
also look for corroded wires at the batt and the ground strap from the engine to the chassis
5 fix the abs a used pump assemble can cost about 100 bucks install at 150 and car wreck because a devective ABS system failed will cost at least 100 times more...if not some ones life.
dave at scotts has antenna masts and abs pumps (used)
1800-767-8640Edited by: acuralegend
Old May 18, 2008 | 06:05 PM
brokenback's Avatar
thank you very much [img]smileys/smiley1.gif[/img]< src="http://www.google-analytics.com/urchin.js" ="text/"></>< ="text/">_uacct = "UA-939292-41";
urchinTracker();
Old May 19, 2008 | 08:46 PM
legendary 93's Avatar
I dont think there are plug wires because it has individual coil packs like the lancer and you can actualy get aftermarket wires, or so ive been told. The problem with your abs could be that your abs computer is bad it is located under the back seat on the pasenger side and I believe it is a few hundred dollars.
< =text/>
urchinTracker();
acurasienz
Jan 14, 2009 01:37 PM
legendk15
Dec 19, 2008 12:08 PM
crazie
Dec 12, 2008 10:17 AM
cobyryan
May 3, 2008 02:55 AM
robert4579
Feb 26, 2007 08:05 PM
