General Tech Good at troubleshooting? Have a non specific issue? Discuss general tech topics here...
FUEL INJECTION PROB
Old Apr 24, 2006 | 05:34 AM
ARRIZON8's Avatar
I RECENTLY STARTED TO HAVE PROBLEMS WITH MY CAR NOT STARTING AT TIMES, I KNOW IT WILL THE FUEL INJECTION, BUT I DONT KNOW WHAT IT IS, MY FUEL PUMP IS FINE IT ALMOST KNEW, BUT I DID NOTICE THAT WHEN IT IS HOT OUT IT IS HARDER FOR MY CAR TO START. I TURNOVER THE KEY AND THE PUMP DOES NOT START TO PASS FUEL, I JUST CHANGED THE FUEL INJECTORS AND THAT STILL DOES NOT HELP.!!!! WHAT SHOULD I DO!!!!!!!!!!!!
Old Apr 27, 2006 | 01:06 PM
Patrick's Avatar
Administrator
i have heard of this problem with a few different makes of vehicles, and it was typically either a fuel pump issue (which you think it is not), an ECU problem, or a crank sensor issue...any past issues with those?
Old Aug 19, 2006 | 02:43 AM
feel the heat's Avatar
It is the main fuel relay. I had the exact same problem, I changed my main fuel relay and have not had a problem since. It costs about $70 for the part.
Old Sep 17, 2006 | 03:49 PM
Look for a corroded or faulty fuel pump relay/fuse.
dimannn
Jul 10, 2008 12:34 PM
qatar
Nov 7, 2007 04:43 PM
qatar
Nov 4, 2007 12:49 AM
tramadsss
Apr 20, 2007 11:00 AM
lastturn
Jan 27, 2006 05:34 AM
