Rack and pinion leaking both sides (any way to stop it?) (3G)
Hi everyone, recently I’ve been seeing drops on my driveway. I got curious and started checking where it was coming from. Attached is the videos of both driver and passenger side and it looks like the rack and pinion is leaking both sides more on the left as that’s where the droplet marks are coming from. I’m just wondering if I need to replace asap? If not I’m hoping I can slow down the leak or if there’s a stop leak or solution for it that would be amazing as I know these are pretty pricy to get a shop to do, and I’m too scared to tackle this job on the floor as it also looks tedious dropping down the subframe. All I’d like to know is if it needs replacing right away or if I can ride it out for a while and if there’s any way to slow the leak down or even solve it as it is a slow leak. Thank you!
